PhD Seminars II
PhD Seminars II
Talk 1
Speaker
Ahmed El Amine Djebri (Wimmics)
Title
Be visible, be heard, be published: a short guide
This is not a scientific talk, yet it is about helping you to publish your science. I will present some best practices, tools and tips to be: more visible, be visible in a "better" way, and most importantly to get your research work out there for others to see it. I will also discuss how to measure your impact in the scientific community.
Talk 2
Speaker
Timothée O'Donnell (ABS)
Title
Numerical computation robustness using geometry as an example.
Algorithms are designed for a machine model with exact real arithmetic, meaning using numbers defined using infinite precision.
However in practice floating point-numbers are used in their place and this may cause implementations to fail.This failure may manifest in an incorrect output, an infinite loop and more.
Using a few geometric algorithm implementations with such failures I'll attempt to give you an idea of how to know in which case you should care about robustness in numerical computations.
  • November 23, 2020, 2:00 pm
